Hi, I’m trying to repair a triac dimmer for a stand lamp.
I already installed a new potentiometer, triac (BTA 08 600B) and diac, but its still not working. The problem is that, regardless of the position of the potentiometer, I get a constant output voltage of 48V.
What could cause this problem? I attached the schematic for better clarity.
I also checked the capacitors with a component tester and while C2 seems ok, C1 has a value of only 87nF.
