Author Topic: Transistor with marking N61G 2D part number  (Read 485 times)
Offline vergrivitTopic starter
« on: May 25, 2024, 08:05:37 pm »
Hi everyone,
Please help me find the part number for a transistor with the marking N61G 2D.
Online fzabkar
Re: Transistor with marking N61G 2D part number
« Reply #1 on: May 25, 2024, 08:26:47 pm »
Could it be a DDTD123EC digital NPN transistor?
https://www.diodes.com/assets/Datasheets/ds30384.pdf
« Reply #2 on: May 25, 2024, 09:11:41 pm »
not sure, the date code doesn't match the one specified in the datasheet, and it's also unclear what the letter G after N61 means.
Anyway, thank you.
Online fzabkar
« Reply #3 on: May 25, 2024, 10:06:37 pm »
Is there a resistor in the base drive? Is it driven directly from digital logic? Does it test as a BJT or MOSFET?
Online floobydust
« Reply #4 on: May 26, 2024, 01:42:21 am »
What package is this? I got close with SOT-23 but it looks smaller
« Reply #5 on: May 26, 2024, 11:35:29 am »
SOT-23
« Reply #6 on: May 26, 2024, 11:43:46 am »
yes
Online fzabkar
« Reply #7 on: May 26, 2024, 05:42:34 pm »
C255 = SN74LVC1G125 - Single Bus Buffer Gate With 3-State Outputs
https://www.ti.com/lit/ds/symlink/sn74lvc1g125.pdf
01C = 10K resistor
The base of the transistor is driven from the output of the logic gate via a 10K resistor, so this would suggest that the transistor is not a digital one. A diode test should confirm this.
« Last Edit: May 26, 2024, 05:46:45 pm by fzabkar »
The following users thanked this post: neoOpus
Online floobydust
« Reply #8 on: May 27, 2024, 01:18:06 am »
Closest I can get is DMN6140L N-ch mosfet SOT-23 60V 1.6A marking code N61. LQ part is AEC qualified.
The "G" must be a variant of it, I don't think it is second-sourced.
