Author Topic: Repairing Anko AO8606 air fryer.  (Read 767 times)
Offline LeWidgetTopic starter
« on: March 17, 2022, 09:22:44 am »
Hi all,
We have an ANKO AO8606 air fryer that suddenly no power. I pulled it apart and probed the AC-IN, but wasn't getting voltage (or continuity from the plug to the PCB in the air fryer).
I dug further and found a thermal fuse in the middle. No continuity on the fuse (but continuity on the plug > fuse, and fuse > pcb. but no beep on the fuse itself.)
Now looking to buy a replacement fuse and heat-resistance sleeve to see if that fixes things.
Anyone know if this fuse will be ok?https://www.ebay.com.au/itm/184832449980?hash=item2b08df5dbc:g:zaYAAOSw7I9hK0S5
^ I can get 3x fuses (couple of spares) for $7, otherwise cheapest I've seen is  1x for $7.50 (Australian dollar)
Also, the heat resistant sleeve. Are these ok,
https://www.jaycar.com.au/high-temperature-basalt-fibre-sleeving-6mm-x-1m/p/WS5511?pos=1&queryId=d4b73cc6941c60e66a64f279c5f98d68&sort=relevance
https://www.ebay.com.au/itm/324922546709?hash=item4ba6e49a15:g:ks0AAOSw6i1hsaA-
« Last Edit: March 17, 2022, 01:00:31 pm by LeWidget »
Offline FIXITNOW2003
Re: Repairing Anko AO8606 air fryer.
« Reply #1 on: March 17, 2022, 12:18:48 pm »
the thermal fuse in link should be ok as they do the 172 deg version you need
the sleeve is good to 200 deg so should also be ok
« Reply #2 on: March 17, 2022, 01:01:47 pm »
Thanks Fixit :)
I might order a couple of them then, so I have a spare just in case. I didn't check, but do these fuses go in a certain way, or can they  be installed in either way (like normal fuses) ?
There was another sleeve too that I link but link seems broken. Would the one from Jaycar be better?
« Reply #3 on: March 18, 2022, 07:50:58 am »
Jaycar  better as higher temp
fuse either way should be ok ,but if you want and they look the same just do same way as original
