Author Topic: Repairing balance control on a Nikko NR-750 Receiver  (Read 897 times)
Offline thevenetianTopic starter
« on: January 02, 2019, 03:31:21 am »
Got this receiver from craigslist for $20 untested and figured I'd take the risk. Got it home and it seems to be working, except that the knob for the balance is loose so when you turn it, its not actually turning the unit inside.
Removed the top of the unit and can see that the screw that holds the plastic knob to the shaft is missing.
Looking for assistance on where I could find that size of screw, or how to even measure it so I can go online and hunt it down. Perhaps there is a set of a certain sized screws I can get and assume it will be included.
See photos.
Offline fzabkar
Re: Repairing balance control on a Nikko NR-750 Receiver
« Reply #1 on: January 02, 2019, 07:48:16 am »
If it helps, it's called a "grub screw".
Offline coromonadalix
« Reply #3 on: January 02, 2019, 06:58:17 pm »
Or called "set screws",  flat screw driver, or hex screw with some allen keys
Not sure of the dimensions, we use at my job metric m2 or m2.5 screws in similar shafts / knobs ...
