Author Topic: Need help finding a buck converter  (Read 1065 times)
Offline german77Topic starter
  • Country: mx
« on: April 26, 2018, 03:45:17 pm »
I have a lot a devices that fail with voltage spikes. Each time the same component burns and I would like to fix them. The real problem is finding the name of the component, as I only know that the package is probably a sot457 , has written the numbers 209 and it's in a buck converter configuration.
The voltage input it's rated at 9v, 0.6A. The output voltage could be 5v or 3.3v. I tried finding the component in digikey and Mouser but had no luck finding the same pin out.
If anyone know a better way to find smd components or know a buck converter with the same pin out even if the package it's a little bit bigger or smaller I would be very happy.
« Last Edit: April 26, 2018, 03:49:27 pm by german77 »
Offline madires
  • A qualified hobbyist ;)
Re: Need help finding a buck converter
« Reply #1 on: April 26, 2018, 04:08:00 pm »
I'd guess it's a TPS562209.
  • Country: mx
« Reply #2 on: April 26, 2018, 04:45:04 pm »
Wow I'm impressed. Just by curiosity how did you find this component so fast? It's so sad that they are out stock, I guess my search continues, thanks any way now that I have a reference it will be much easier.
« Last Edit: April 26, 2018, 04:55:57 pm by german77 »
Offline madires
« Reply #3 on: April 26, 2018, 05:21:18 pm »
Basic google-fu. ;) I searched for "smd code 209 buck converter".
« Last Edit: April 26, 2018, 05:23:33 pm by madires »
Offline SaabFAN
« Reply #4 on: April 27, 2018, 12:14:09 am »
Check the portfolio of Linear Technology (now Analog Devices) for Chips with the same pinout.
You should also get a outlet-strip with spike-protection to prevent that kind of damage in the future (if the spikes come from the mains) :)
  • Country: mx
« Reply #5 on: April 27, 2018, 12:30:46 am »
Hahaha. That was my first try, but I din't put "code" the results are totally different .
Thanks I will take a look on it. These devices are for customers, who were told to put spike-protection but they din't, like always.
