Attempting repair of a Secop Electronic Unit for BD35 compressor, company formerly known as Danfoss.
Model 101N0500 for 12/24V BD35 compressor
Replacement unit is $150 plus postage
Board drives the BLDC motor in the compressor, and has 3 output mosfets, two of which are blown.
Surviving mosfet says
IRF P222J
8DFA
F7343
It's a SOIC-8 package
Cannot find any datasheet for this International Rectifier part.
Not found anything yet on power draw, bar a data sheet that recommends the main battery switch be rated to 20A.
Only advice I've found on this unit is to replace it with a 48V BLDC controller for ebike, which then needs 48V to run to compressor at the same speed.
