For those who frequently contend with the old 1980's HP "click" switches, I've found a somewhat palatable alternative. You can
replace the entire switch mechanism which are usually heat-staked into position and cannot be reinstalled once they are removed.
The problem is that the last time I inquired, Agilent wanted something like $25+ for a new switch (who knows if they have any left now).
BUT, I had an old defunct HP 3437A voltmeter lying around and the switches in them are NOT heat-staked (they are held down by brackets).
I don't have a heat-staking tip for my soldering iron, but a broad tip will work if you are fast and precise. The good news is that HP 3437A's
go on eBay often really cheap (like $25). For basically the price of one new switch from Agilent, you can have 13 new ones!
