New to electronic work, built/copied a few tube amps, now trying my hand at more in-depth stuff that will make me learn more.
I needed a function generator, so I have acquired a few. I got one Heath 1274 that seem to work fine, so that’s for my guitar amp work, but I did get two old BK Precisions, a 3010 that is from the late 70s, and a 3011 from the 80s. I know it’s worth nothing value wise, but it works enough it’s of potentially great value to me as something to learn on.
Both have a sine wave that has a noise at both peaks of the cycle. (See image)
So know very little about the functions other than I understand the triangle wave is being used to make the sine wave.
I have the PDF manuals to calibrate both, and the schematics with part lists for both.
Any idea what this is? Or where to start testing for proper functions?
I should add, I have acquired an oscilloscope. Sig 1202x-e
