Author Topic: Repairing SL-1730SL20A Power supply. What is this component  (Read 2406 times)
Offline JacquesBBBTopic starter
Dear All,
I am trying to repair a linear 0-30V - 0-20A Power supply (SL-1730SL20A). The design is very similar
to the more classical  0-30V - 0-3A,
https://www.eevblog.com/forum/repair/tracking-problem-in-a-dual-bench-power-supply/msg529140/#msg529140
but with a much larger transformer and a single canal.
I suspect now that the problem comes from some shutdown feature, and came over this component which
I cannot identify. Quite surprisingly, it was connected only on one side, and the wire on the other side was cut.
Is this a thermal sensor ? If yes, what should be its resistor ?  Thanks !
Re: Repairing SL-1730SL20A Power supply. What is this component
« Reply #1 on: June 05, 2017, 09:05:27 pm »
A view of the inside.
The unknown device is circled in white.  It was screwed on the heatsink of the power transitors.
Offline anachrocomputer
« Reply #2 on: June 05, 2017, 09:12:50 pm »
Yes, it's a thermal cut-out. It opens the circuit at the marked temperature (75 deg C). If it's working properly, the two terminals should be a short circuit. When it gets too hot, the switch opens. The switch is rated for 220V, 1Amp.
« Reply #3 on: June 05, 2017, 09:18:23 pm »
Thanks,
Obviously, it is not working, as it is open at room temperature ( 20 °C).
My problem is  that I do not have the schematics and  one of the wires  of hte sensor was cut.
I do not see very well where it should go.
below is the main board. The sensor is connected on one side on 29 ( lower left) which goes then on
the + of V4 (top left).
« Last Edit: June 05, 2017, 09:20:40 pm by JacquesBBB »
