I have an 90's TI calculator with about 7mm of a trace missing from its keyboard matrix - which is PET film - leading to several non functional buttons. It's a nice calculator, not worth the time to repair, but I'm using it as practice in case I need to do it on something more important/expensive.
There also, a few mm missing from one of the carbon fingers used for one of the buttons - this is less important as it looks like the other fingers will sitll make conact, but as it is one of the affected buttons it can't be tested yet. Would be nice if I had a way to repair these as well.
So, my thoughts are:
1) copper tape with conductive adhesive. I had some, tested it on OHP film with two strips and it worked (R = ~ 20ohm), but every time I try and lay at few overlapped mm-wide strips to make a trace, one of the connections between the strips never connects. I've tried pressure, and replacing strips, can't get it to work - I'm unsure why, but its unreliable. The original traces are about 6mil and way less than 35um thickness, it seems getting a good conection to these is difficult.
2) I've seen conductive glues/inks, and have a very old vial of "silver ink" (Labelled: Leitsilber L100) that I've tested on OHP film - waiting for it to dry, but its so thin it will not form thin tracks an a plastic surface, plus I'm sceptical about its usefulness - given its 15 years old I dont' know if its just age or this is just the wrong application.
3) I have seen "wire glue" the carbon/black stuff. This seems to set hard, similar to the carbon fingers used on keyboard. This seems more promising, and if its thick I can at least use to to repair the carbon fingers, and join copper tape strips to form traces whilst still keeping it thin. Has anyone used this?
Given its on PET film soldering is out of the question. I've googled it and theres a lot of either very old websites for restoring vintage equipment (that don't have flex/PET film) or questionable amateurs.
