Author Topic: Repairing water damaged electronics  (Read 17089 times)
Offline EntropiaTopic starter
    • My blog
Re: Repairing water damaged electronics
« Reply #25 on: October 07, 2012, 07:46:59 am »
Entropia:  Your gallery hosting software looks great!  Is it open source, by chance?
Nope, it's a bought service, the software is prorietary to the gallery service provider.
Anyway, some progress, I guess. Cleaned all the boards "enough" and tried plugging in the power. It draws a constant 150 mA with only the battery+ terminal switched. If I connect the ignition-pin to 12V the current draw doesn't change. 150mA is way too much for "sleep" current anyway. I've been searching for a service manual / schematic like mad but there just doesn't seem to be one on the internet. I even asked the Finnish authorized Blaupunkt service but they said they don't ever get the OEM stuff manuals. Dead end. I could ask Blaupunkt at Germany directly but frankly I don't expect any miracles...
Someone suggested desoldering all the parts but that's just out of the question. I tried to solder a few testpoint wires to various power supply components but frankly, it's impossible. The corroded solder will not melt. I even blasted the solder at 450C for as long as I dared but nothing. I fear the PCB tracks will lift off before the solder melts. I tried applying shitloads of flux and using good quality solder but in vain.
Tracing out the circuits is also impossible. The main PCB seems to be 4 or 6 layers. This is turning out to be a harder than I thought!
Offline amyk
« Reply #26 on: October 07, 2012, 12:55:01 pm »
A careful bit of grinding might help penetrate the layer of corrosion. Of course, you should have a blob of molten solder on the iron for good heat conduction.
Offline Rerouter
« Reply #27 on: October 07, 2012, 01:01:00 pm »
i know the level of oxidistaion he is refering to personally (had an insturment cluster that had been through a few weeks of flooding) the only way i could break it down was to first scrape at the joint a little to get some metal exposed, hit it with the desoldering braing to remove the solder and then flick off the corroded layer with a scribe (it actually seperates fairly easily) it was just a pain in the butt like what your working on now in that it had a few hundred joints, and also damaged traces,
« Last Edit: October 20, 2012, 12:00:48 am by Rerouter »
Offline Dago
    • Electronics blog about whatever I happen to build!
« Reply #28 on: October 18, 2012, 07:18:32 pm »
This SMPS I have had layed in the ground for years in the rain, with a thorough washing and drying it's (almost) as good as new :)! http://www.dgkelectronics.com/fixing-water-damaged-ascom-48vdc-switchmode-power-supply/
Come and check my projects at http://www.dgkelectronics.com ! I also tweet as https://twitter.com/DGKelectronics
Offline Zero999
  • 0999
« Reply #29 on: October 19, 2012, 05:58:56 pm »
Hmm, I'd be suspicious, just because it works, it doesn't mean it's still safe. The isolation between the primary and secondary on the transformer may have been weakened.
