Author Topic: Repair/Restoration Adret 103A Current and Voltage standard  (Read 6190 times)
Offline BFXTopic starter
  • Country: sk
« on: November 22, 2016, 09:29:32 pm »
Few months ago I bought this guy as broken and finally I got service manual, now is time to repair.   :-DMM
First of all I found that +- 15V rails are not so good.
Two 15ohm resistors are broken but why? After replace magic smoke escaped :D
Aha tantalum caps  :-- both at output had resistance around 50ohm (not so common that they are not fully shorted).
Now is time to order some spare parts.
Question
is what to use as replacement for those tantalum bastards. What is your suggestions guys?
Again tantalum or electrolytic or ceramics? Because most of them are 4.7uF/20-40V.
« Last Edit: November 23, 2016, 08:53:00 pm by BFX »
  • Country: sk
Re: Repair/Restoration Adret 103A Current and Voltage standard
« Reply #1 on: November 23, 2016, 07:28:11 pm »
Next part is about Mains Dropout Protection.
Function of this circuit is not so clear for me.
If battery is connected all digital part is powered, also in case if main switch is off.
Surprise for me was that Q4 is on board connected differently collector - emitter are upside down.
Simulation is exactly like is it connected on PCB.
I did some simulation and behavior of circuit is different, but I can't find any bad component.
« Last Edit: November 25, 2016, 08:57:28 pm by BFX »
Offline acbern
« Reply #2 on: November 23, 2016, 11:15:11 pm »
Would not use Tantalums, these days organic electrolytics are better (goof HF behaviour, no nasty failure modes). I used Oscons everywhere on my 4910 after the tantalums started to die.
  • Country: sk
« Reply #3 on: November 25, 2016, 09:05:17 pm »
Thx I have the same opinion.
Would be great guys to explain me how It works, this dropout protection, because I'm totally confused from this circuit  :palm:
Online Kleinstein
« Reply #4 on: November 25, 2016, 10:27:41 pm »
To me that dropout protection circuit looks like a charging circuit. If mains supply is there, the battery is charged up to a voltage of about 5.2 V + drop of D2.
  • Country: sk
« Reply #5 on: November 27, 2016, 08:13:17 pm »
Offline Theboel
  • Country: id
« Reply #6 on: November 30, 2016, 10:46:03 am »
Hi BFX,
Just curious becaused I can not find the schematic,
Could You upload the Voltage reference parts and or parts of service nabual about it. Thank You
I replace handful tantalum cap from my HP 8590L with OSCON SA cap and guest what the noise floor get down measurably I do not say spectacular but measurable.
  • Country: sk
« Reply #7 on: November 30, 2016, 06:53:56 pm »
Hi BFX,
Sorry, it takes long time and effort to find this service manual. It's not so good, but better like nothing  8)
Here is it http://www.eternal.sk/Adret103A.zip
About capacitors ... I can't find OSCON SA  4u7/36V at Farnell. What about caps which I mentioned?
  • Country: sk
« Reply #8 on: December 17, 2016, 01:22:51 am »
Good news  8) unit is working  :-+ (see photos)
Primary problem of course tantalum caps.
All was replaced  and also 15 ohm resistors in +- 15v power supply.
That was root cause. Additional components shouldn't be changed but during investigation it was.
Next step is confirm the specs, clean the unit and keyboard contacts and do the calibration.
Sorry photo is not so good, but now is 2:30AM and I need to sleep :D
« Last Edit: December 17, 2016, 01:34:46 am by BFX »
  • Country: sk
« Reply #9 on: December 18, 2016, 04:37:37 pm »
Some basic measurements:)
Looks very good, but I think that calibration is necessary, question is if official calibration is necessary :-//
Probably I should replace some resistors which are out of spec and I found it during repair.
« Last Edit: December 18, 2016, 05:31:22 pm by BFX »
