I just went through a process of experimenting and repairing a fiber glass shaft extension for 11801 adjustment on HP-105B. Mine was there but the fiberglass shaft was so damaged by heat that it no longer functions as needed. A little metal tab that acts as screw driver blade at the tip of fiber glass piece has come completely loose.
I went through iterations but what finally worked was to cut off the original piece and glue in a tip harvested from ceramic tip screw drivers. I used this screw driver for parts. A small hobby lathe was used to drill a coaxial hole onto fiber glass shaft. As attached image will show, the finished part is a little shorter than the original, but it still works well.
https://www.ebay.com/itm/ENGINEER-DA-72-Ceramic-Driver-0-4x2-4mm-Stock-in-USA/172416675691?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649Please see
