Like others said, most of the time, the red glowing light lamp is a neon bulb. If it is hard to source, you may scavenge it from some mains switch with indicator light.
However, I have seen some glass electric kettle with ring of bright blue light at the bottom. I guess that comes from some LEDs, not neon bulb.
