If you ever had a vintage gear where you needed to get it to work but needed a replacement for Germanium transistors especially in audio circuits and you wondered if simply replacing with Silicon PNP transistors would work (with some tweaking and minor adjustments), the answer is yes.
I got a Siemens Club RK 231 vintage radio which had two dead audio output transistors AC141/ AC142. These are hard to get and I needed to get the radio working for somebody who didn't mind modifications, though I prefer vintage repair.
So I replaced them with BC327 for the AC142, and BC337 for the AC141. I had to add some cooling stuff and luckily there was a quiesent current adjustment trimmer.
I had another vintage russian VEF 204 radio,
http://www.radiohistoria.sk/Oldradio/main.nsf/wcatalid/0002688. The two output PNP Germanium transistors (MP41)were also damaged. I just replaced them with two BC327, and had to fiddle a bit with biasing, and the audio amplifier worked just fine!
The third attemp was trying to repair the audio amplifier of a Siera vintage transistor radio. Unfortunately, the cover had lost all other information. I couldn't find a similar schematic I almost checked all semiconductors resistors capacitors, but all in vain. I gave up and the owner dindn't mind an LM386 instead!
