Electronics => Repair => Topic started by: brauliochi on April 26, 2017, 05:03:10 pm
Title: Replace M25PE10 flash memory obsolote from AMS control board vending machine
Post by: brauliochi on April 26, 2017, 05:03:10 pm
Hi, I fix a control board from a vending machine, I check that two components is in short, a fram fm25v02, and m25pe10, with the first no problem, mouser have in stock, but the m25pe10 its obsolete, and the only place that they have in stock is aliexpress, and dont trust so much in this supplier, any now any substitute for this chip, best regards
Title: Re: Replace M25PE10 flash memory obsolote from AMS control board vending machine
Post by: Anks on April 26, 2017, 06:46:17 pm
Arrow have them in stock. Have you got the info to burn to it?
