Author Topic: Replacement 3.5mm stereo jack  (Read 1637 times)
Offline MrQuadeharTopic starter
« on: July 14, 2017, 11:47:26 pm »
Hello Ladies and Gents,
 i need to replace my laptop headphone jack of my asus r753ux. I desoldered it and used the search engine from digikey but i didn't find it. Maybe one of you know the model numer of the jack. Size is approx. : 15 mm x 10 mm x 5 mm, seven pins. Mounded inside a cutout in the main board and then soldered through-hole (kind of). Sadly, there is nothing printed on it. I have attached some photos of the device <http://imgur.com/a/nVfZY>
Thanks in advance
MrQuadehar
« Last Edit: July 15, 2017, 12:49:26 am by MrQuadehar »
Offline Richard Crowley
  • KJ7YLK
Re: Replacement 2.5mm stereo jack
« Reply #1 on: July 15, 2017, 12:27:53 am »
First, you almost certainly have a 3.5mm jack, not a 2.5mm jack. So you might have marginally better success searching for the proper part.
That said, finding an exact match for a rather obscure connector like that seems pretty slim.  You may have to replace the whole main board, or at least get a non-functional "donor" board and do a connector transplant.
Louis Rossman has a quite successful repair business and YouTube channel where he keeps a "junk-yard" of old laptop main boards and regularly repairs units for customers by removing parts from "donor" boards and transplanting them to accomplish the repair.
« Reply #2 on: July 15, 2017, 12:40:18 am »
Thank you for your fast response. Yes, of course its a 3.5mm that was a typo. Maybe i try to squeeze an off the shelf jack i have lying around into the laptop case and bodge the connections with fine wires. Changing the whole board is most likely not an option for me as i'm on a very tight budget.
  • KJ7YLK
« Reply #3 on: July 15, 2017, 12:43:13 am »
Do you have any possibility of access to discarded laptop hardware where you are?  If you could find a discarded non-functioning similar model, you could probably transplant the connector.
Offline Rasz
    • My random blog.
Re: Replacement 3.5mm stereo jack
« Reply #4 on: July 15, 2017, 05:03:18 am »
http://www.ebay.com/itm/audio-Jack-Interface-for-Laptop-32-types-set-each-2pcs-total-64pcs-audio-jack-/301437029668
hehe
edit:
but seriously, your connector is in related searches on ebay listed at $2
« Last Edit: July 15, 2017, 05:15:46 am by Rasz »
