Author Topic: Replacement capacitor in inverter  (Read 434 times)
Offline FactotumTopic starter
  • Trying to realize my potential.
    • Factotum Industries
« on: May 02, 2023, 11:09:46 am »
Scenario : 12v "Gen Power" automotive inverter (240v, 2000W) has pooped the bed. Won't run an AC load.
The main capacitor (marked CBB22 106J500V) is split with dried electrolyte everywhere. No schematic that I can find. Appears to be part of the final output and (in parallel to the output socket with other components).
So it seems I'm in the market for a 10uF cap to see if this thing will live to fight another day.
My Googling suggests the CCB22 are general purpose metallised polypropylene caps.
Am I able to use a MKP cap such as the following as a replacement?
https://au.mouser.com/ProductDetail/EPCOS-TDK/B32754C2106K000?qs=HXFqYaX1Q2zPCzOHO1GRmw%3D%3D
Would rather a real cap from a real supplier than another junk one...
An artist trapped in a scientist's body.
Online wraper
  • Country: lv
Re: Replacement capacitor in inverter
« Reply #1 on: May 02, 2023, 11:15:21 am »
You should use 630V cap or X rated 250+VAC if it's connected in parallel to the output. Original part seems to be underrated. Also film caps do not have electrolyte.
Online wraper
  • Country: lv
« Reply #2 on: May 02, 2023, 11:27:51 am »
Although particular 500V TDK cap should be fine, it has sufficiently high AC rating.
