Author Topic: Replacement diode for inverter, help needed  (Read 1777 times)
Offline scottc19Topic starter
« on: January 15, 2021, 07:35:49 pm »
I need a replacement diode for the inverter I am trying to fix.  I'm guessing its a beefy schottky diode, my dmm says a VF of 460mv.  There's a double diamond logo and the diode has ER5026 on it.  Any idea what diode I should order to replace the blown one.  Also if I just replace one is my efficency going to be crap because the (some type of rectifier) well matched?
« Last Edit: January 15, 2021, 07:38:11 pm by scottc19 »
Offline fzabkar
« Last Edit: January 15, 2021, 08:17:36 pm by fzabkar »
The following users thanked this post: scottc19
Re: Replacement diode for inverter, help needed
« Reply #2 on: January 15, 2021, 08:47:49 pm »
ER5026, ULTRAFAST EFFICIENT GLASS PASSIVATED RECTIFIER, 260V, 5A, 35nsec, DO-201AD:
http://www.cumsumi.com.cn/uploads/soft/200612/ER5026-ER5028.pdf
https://webcache.googleusercontent.com/search?q=cache:http%3A%2F%2Fwww.cumsumi.com.cn%2Fuploads%2Fsoft%2F200612%2FER5026-ER5028.pdf
Vf is 1.0V at 5.0A.
Thanks thats it!
It doesn't look like I can buy those anymore, but I'm thinking this guy will do the job, different package and higher current rated.  Any thoughts?
https://www.mouser.com/datasheet/2/427/vs-8eth03s-m3-1769743.pdf
Thanks again!
Offline fzabkar
« Reply #3 on: January 15, 2021, 08:58:03 pm »
That looks electrically OK. However, I would think that it shouldn't be too hard to find a replacement diode in the same package. :-?
« Reply #4 on: January 15, 2021, 09:15:22 pm »
I had a hard time finding one that met the same Reverse recovery time Trr for the given If and Reverse voltage.
Offline fzabkar
« Reply #5 on: January 15, 2021, 09:21:14 pm »
I just had a look and had the same trouble. :-(
Offline teapilot
« Reply #6 on: August 04, 2021, 08:04:50 pm »
Im looking for the same diode at least 24.  number on it is ER5026 (9.2 mm Long x 5.1 mm dia.)
Offline jmpaul
« Reply #7 on: May 26, 2022, 03:49:05 am »
Did you ever find a replacement for the ER5026?  I think we're all looking to fix the same Xantrex inverter or its equivalent.  I found one hard shorted diode of 24.
« Last Edit: May 26, 2022, 03:51:47 am by jmpaul »
