Author Topic: Replacement for 6pin power ic "IDP=H02"  (Read 1205 times)
Offline sdancer75Topic starter
  • Country: gr
« on: October 07, 2022, 05:35:12 pm »
A Chinese power 6 pin IC smd with mark "IDP=H02". It removed from a adsl router power supply. Is there any chance to find the datasheet or even better a replacement one?
Regards
Offline fzabkar
Re: Replacement for 6pin power ic "IDP=H02"
« Reply #1 on: October 07, 2022, 07:26:13 pm »
R7731A, Richtek, Burst Triple Mode PWM Flyback Controller, marking IDP=W, SOT-23-6:
https://www.richtek.com/assets/product_file/R7731A/R7731A-10.pdf
  • Country: gr
« Reply #2 on: October 08, 2022, 04:54:04 pm »
Excellent thanks 👍
Anyway, any idea how to test it?
Regards
Offline fzabkar
« Reply #3 on: October 08, 2022, 05:34:12 pm »
One common fault in this topology is an open startup resistor between the Vcc pin and the rectified mains. Be aware that these faults leave 350VDC sitting on the bulk capacitor.
  • Country: gr
« Reply #4 on: October 08, 2022, 07:15:40 pm »
Dead resistor between the Vcc and the rectified mains which are pin 5 Vdd (SOT 23-6?) and the point just after the rectifier bridge of the primary?
I suppose this is an smd resistor because in the primary top surface there is only one resistor which is fine. All parts was fine except the photo-resistor of the optocoupler which I replaced but it still dead.
Regards
« Last Edit: October 08, 2022, 07:22:47 pm by sdancer75 »
Offline fzabkar
« Reply #5 on: October 08, 2022, 07:21:09 pm »
Another common fault is that the capacitor on Vdd often dries out. I would also test for shorted outputs on the secondary side.
  • Country: gr
« Reply #6 on: October 08, 2022, 07:26:54 pm »
I tested everything from the top side ie all capacitors, mosfet, resistors etc. Everything was found ok except optocoupler. The smps stopped to work after a storm thunder ⚡⚡⚡.
All smd resistors from the back side seems to be also ok, so I suspect the pwm driver...
Offline fzabkar
« Reply #7 on: October 08, 2022, 07:47:50 pm »
What voltage do you measure at Vdd?
  • Country: gr
« Reply #8 on: October 09, 2022, 12:29:58 pm »
Hi
I didn't test the power supply connected...it is dangerous, don't you think?
Offline fzabkar
« Reply #9 on: October 09, 2022, 04:32:05 pm »
Yes, it's dangerous. Ideally you would use an isolation transformer.
The following users thanked this post: sdancer75
