Hi everyone,
Just wondering if someone could please help me?
I have a Soniq U65TX14A-AU, when I power it on the back light works and the start up sound plays but no image.
What happened was after some time when it did work it would get a green image running from top to bottom and I would turn it off and on after 5 min it would be fine.
Now it has no display.
I opened it up. Checked the 5 and 24v rail on the main board. However I noticed the heat top heat sink was lifted on what I think is the BGA LCD Chip.
Would replacing the main board - U65TX14A-AU - Main Board -(ST6369IV-TC1) (222-665006002-30) work?
Or should I replace the main board along with the
Tcon Board -(6870C-0466B) ?
Any way I could prove it's that particular component which the heat sink was not secured too? I think it would be the BGA LCD TV chip that the heat sink was lifted. I dont have a reflow station.
Any help would be greatly appreciated, I am new here and new to electronics. Only repaired minor boards like PDB,s and Flight controllers. Just don't want to throw out something if it can be fixed.
Cheers
