It's just an EMC capacitor, these loose capacity over time anyway, and sometimes fail like yours. The mixer will work fine without that component, so just save yourself the hassle of finding a replacement. You'll have to connect the AC line wires from one side to the other, as they go straight through, cut off the 5th wire (I'd expect this one connected so some metallic components inside the mixer).
