I've noticed things being very dry at home recently and decided to check out the Honeywell Humidifier attached to our furnace. It is bone dry. It is humidifier model HE225A1014 (solenoid and control 24 VAC, 6 Watts, 60 Hz). I checked the water line going to the solenoid... there is water definitely going to it. I checked the output (rubber tube attached to a nipple at 90-degrees) and NOTHING coming through when supposed to.
To test, I turned on the furnace as the solenoid only activates when fan blower is on. At that time, I turned the humidity control up/down and could clearly hear the solenoid buzzing. I turned it all the way up... control "clicked" and so did solenoid click and start buzzing. So I know there is voltage going to it... yet NO WATER coming through. Output line is clear... I removed it and just checked nipple directly... still NO WATER. I figure it is the solenoid that is buggered as the furnace is maybe 12 years old now.
Anyways, all I need is to replace this simple valve. I am not sure where to buy it. Is there no store IN CANADA in the Toronto area that has simple replacements for these things? I see some options online but there are different part numbers:
32001639-002 (is the part number written on mine, Kip Inc. Valve No. U147112-24/60, Kip Ref 1x1225).
I see some replacements but they include an extra "9" in the number before the 39... e.g. 320016939-002.
For example, like this one from Amazon:
https://www.amazon.com/dp/B081N7D513/ref=sspa_dk_detail_3?psc=1&pd_rd_i=B081N7D513&pd_rd_w=sQaoc&pf_rd_p=45a72588-80f7-4414-9851-786f6c16d42b&pd_rd_wg=Bs9aZ&pf_rd_r=QFC1APEHAKW2H9W4ZKNQ&pd_rd_r=f451391e-886a-4d7d-b681-8940b4c2a7a3&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFWUlpWN0s5MlIxV0YmZW5jcnlwdGVkSWQ9QTA0OTYzMDAyV1dGTVdaRk9MMEtaJmVuY3J5cHRlZEFkSWQ9QTA4NjE1OTczUk9LUElUNUc2Wkg3JndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==Also prices range from $30-40 shipped to $100+. Can anyone please suggest a furnace parts place in the Vaughan, Toronto area that may stock parts like these that can be bought by the public? I can't seem to find anything except online and I don't want to order something wrong or pay 10x the cost. Surely there must be a place I can walk in with my valve, look at what is available and walk out with a replacement. I am still assuming my valve is not working. I can't see any other reason why it be anything else, as water is going to the valve, the output line is clean and I've tested the humidifier control and hear clicking/buzzing going from the valve when it is activated. Must be the solenoid???
