Hi to everyone,
on the bench i have a board which uses Moxie TS3-75 for the temperature protection. It is a NTC in a TO18 package and has a very narrow transition region around 75°C. You can see in the attached datasheet. The NTC is faulty as it is floating around 35kohm at room temperature. Should be at around 300kohm according to datasheet.
I also included a picture of the NTC desoldered and how it is squeezed against a heatsink, so you can see how much space is there for improvisation.
The problem is that i cannot find an appropriate substitution for it. Any idea?
