Author Topic: Replacement relays for Keithley 2001-TCSCAN card ...  (Read 638 times)
Offline mossygreenTopic starter
« on: May 28, 2021, 09:00:15 pm »
I have both the Keithley 2000-SCAN and 2001-TCSCAN cards for use with a DMM6500, purchased well used. All the relays on the 2000 and all but two of those on the 2001 are of the same type. Just so that I know I'm starting with a fresh set of relay contacts I have replaced the common ones on the 2000 card and will do the same with the 2001.
Unfortunately I don't know how to identify a comparable part to replace the remaining pair of relays on the 2001-TCSCAN. From the standpoint of a newbie, relays are an astonishingly diverse world.
The parts themselves are labeled as being Aromat TF2E-5V-H38's and are referred to as "RELAY, ULTRA-SMALL POLARIZED TF2E-5V" in the Keithley manual for the card. They appear to switch in some current limiting resistors for channels 5 & 10 (I don't exactly grok why those are needed).
I've attached a thumbnail from the schematic and some potentially relevant info is here:
https://datasheetspdf.com/pdf-file/980252/ETC/TF2E-5V/1
Additional info on the part label:
ATF209 C01
LR26550 50124
Any direct pointers would be appreciated, or places to go learn enough to figure out what I need to purchase.
Online coromonadalix
Re: Replacement relays for Keithley 2001-TCSCAN card ...
« Reply #1 on: May 29, 2021, 06:34:47 am »
Many places i've checked  say the TF2 series are discontinued ?? not so sure,  and some give the TQ2 series as a substitute ??
Like the TQ2-5V
https://www.digikey.com/en/products/detail/panasonic-electric-works/TQ2-5V/251773
at 3.42 usd a piece
« Last Edit: May 29, 2021, 06:38:04 am by coromonadalix »
The following users thanked this post: mossygreen
