Author Topic: SMD Component with Marking Code 3B 514  (Read 1407 times)
Offline 2XTopic starter
  • Country: gr
« on: August 20, 2023, 10:35:57 pm »
Hello,
I can't find what component is this on the attached picture. It has on it the Marking Code 3B 514.
« Last Edit: April 19, 2024, 10:49:26 pm by 2X »
Offline amyk
Re: SMD Component with Marking Code 3B 514
« Reply #1 on: August 21, 2023, 01:52:49 am »
Of all the possible 3B SOT-89 I've found, KIA431AF is a good guess, given that it goes to a reference voltage input and how it's connected makes sense for a 2.5V reference.
The following users thanked this post: 2X
  • Country: gr
« Reply #3 on: August 21, 2023, 05:21:10 am »
Hello,
the part number "KIA431AF" where did you find it? Because on the below smd marking codes sites didn't show me the "KIA431AF".
http://www.smdmark.com/en-US/search/code?id=B3
https://www.s-manuals.com/smd/b3
http://markingcodes.com/search/c/B3
Offline fzabkar
« Reply #4 on: August 21, 2023, 05:37:03 am »
http://markingcodes.com/search/c/3b
Keep clicking "NEXT" until CURRENT=6.
BTW, your links are searching for B3, not 3B.
« Last Edit: August 21, 2023, 05:38:37 am by fzabkar »
  • Country: gr
« Reply #5 on: August 21, 2023, 10:11:51 am »
I apologize for my mistake... One more question... You search with order all the codes that shown on the site until you will find a voltage reference component or you use another method. Many thanks for your help.
Offline fzabkar
« Reply #6 on: August 21, 2023, 05:08:54 pm »
You can mentally filter the search results by package type. In this case I was looking for SOT-89 or similar. Next I look for circuit context (which you provided) to narrow down the candidates.
Finally, I try to find a photo of the part:
https://www.google.com/search?q=KIA431AF&tbs=isz%3Am%2Citp%3Aphoto&tbm=isch
https://www.aliexpress.com/wholesale?catId=400103&initiative_id=&SearchText=KIA431AF
« Last Edit: August 21, 2023, 05:22:46 pm by fzabkar »
  • Country: gr
« Reply #7 on: August 22, 2023, 07:53:18 pm »
Many thanks for your help. I made a schematic about how the two components "Marking Code 3B 514" interconnected on the PCB with the other components. According to the connections I believe you are totally right that the "Marking Code 3B 514" is a voltage reference. Also, I measured all the pins of the component between them with a multimeter in diode mode.
« Last Edit: August 22, 2023, 07:55:29 pm by 2X »
Offline fzabkar
« Reply #8 on: August 22, 2023, 08:47:40 pm »
To be fair, @amyk found your IC. I just added my links to help you in your future searches.
  • Country: gr
« Reply #9 on: August 22, 2023, 09:45:30 pm »
Thanks a lot for the help and your time.
