When replacing TV caps you should 99% of the time replace the cap with a cap of the same capacitance value. The voltage can be equal to the original or higher, not lower. I usually order the same exact one I'm replacing (same capacitance value, same voltage rating, same temp rating, same manufacturer). The more special characteristics of caps play even a higher role when talking about audio circuits. Hope this helps!
