Just bought a Fluke 189 from ebay, opened the battery compartment, and found that the foam padding in it turned to goo. I was able to get all of it out using alcohol.
The question is, what should I replace it with so that it does not deteriorate in the next few years? Without the foam the unit is running fine, but i'm afraid that the batteries may become loose in the compartment.
