392k is 10k lower, but you may compensate it by removing another 402k resistor from string and replacing it with 412k resistor, so that total resistance of string will remain the same. 412k resistor will have a few percent higher power loss and voltage across it; but any sensible design should be de-rated so it shouldn't matter much.
412k in E96 series too, so you may be lucky and find it in stock. If not, you may try to find another combination, but do not deviate much from 402k, because of voltage across resistors and power loss.
