Author Topic: Replacing old five pin capacitors  (Read 1496 times)
Offline reddish75Topic starter
« on: September 22, 2022, 03:19:23 pm »
I am finally thinking about refurbishing an Audio Research D76 someone gifted me and am wondering on the best way to replace the power supply caps (x6 600uf 300v) they are five pin I think old Mallory caps. I have seen an adaptor someone made for a broken Tek scope but I'm not sure they would be suitable for the voltage I need as they replaced 75v caps (please see pic) the other option seems new caps of that value and voltage tend to be snap on would be to drill the pcb and jumper one terminal across. Any thoughts?
Online Grandchuck
Offline james_s
Re: Replacing old five pin capacitors
« Reply #2 on: September 22, 2022, 05:18:19 pm »
A lot of guys just install new modern capacitors under the chassis and leave the originals in place but electrically disconnected. If you want to get fancy you can disassemble them, pull out the guts and stuff modern parts inside them, usually new capacitors are smaller and can fit in the old can.
The following users thanked this post: boB
Online wraper
  • Country: lv
« Reply #3 on: September 22, 2022, 05:22:16 pm »
Imho you could just put a new capacitor into positive and one of the negative holes which match the pin pitch the most. Of course it does not work if you want to retain original look.
Offline Gyro
« Reply #4 on: September 22, 2022, 05:31:03 pm »
Irrc, on some Tek 400 series scopes, the PCB uses capacitor negative tabs for trace continuity. Not a problem, but you do need to check and, if necessary, jumper the pads to maintain continuity.
Best Regards, Chris
Offline floobydust
« Reply #5 on: September 22, 2022, 05:41:03 pm »
I've made adapter PC boards then foolishly realized the new snap-in cap has 7.5mm or 10mm lead-spacing and can just fit right on the main board between two (old) pins. Try measure it. I add jumpers if required to join the extra case pins.
« Reply #6 on: September 22, 2022, 06:10:52 pm »
This was thought about and I do like the idea in keeping the original look but I don't think I'll go down this route as I like to know everything is installed properly and will last.
Good information to keep in mind but it's not a Tek scope it's a valve amplifier
Problem is the caps have individual cut outs on the chassis which they go through although one pin will line up the other wont
http://www.rsdsound.co.uk/product/axial-to-radial-electrolytic-capacitor-adapters/
Thats a good adaptor but not the type I was looking for
« Reply #7 on: September 22, 2022, 06:17:55 pm »
Has anyone used the adaptor in post one for 300vdc + or have an opinion about its suitability?
Online wraper
  • Country: lv
« Reply #8 on: September 22, 2022, 06:27:27 pm »
Then I would lead form negative lead very close the the can, maybe put some insulation on the lead. Then before soldering put a blob of electronics grade or just usual neutral silicone under the cap for mechanical support.
Offline Gyro
« Reply #9 on: September 22, 2022, 07:32:37 pm »
That doesn't mean it's the only place it has ever been done, always check. The consequences of an open 0V trace on a valve amp PCB could be considerable.
« Last Edit: September 22, 2022, 07:35:37 pm by Gyro »
Best Regards, Chris
« Reply #10 on: September 22, 2022, 07:39:15 pm »
Absolutely! Just wasn't sure you realised it wasn't a scope
