Hey,
I have a Simpson washing machine that has touch-sensitive buttons for selecting wash settings, as well as the start/pause button. The start/pause button has become intermittent and sometimes the machine pauses itself in the middle of a cycle. I pulled it apart and found one of the two 400V 4.7uF mains filter caps was bulging, it reads 3.6uF and nothing on my ESR meter, the healthy looking cap measured in spec and around 6.5 ohms ESR. I replaced both caps and am going to test it tonight.
As per the title, I'm curious what people would use as a replacement potting/encapsulation material. The original material is soft and was actually quite easy to remove, the consistency is like that of gummi candy. It didn't seem to have bonded all that well to the board or components like most silicone I have used, I removed it easily with a greenwood stick. Ideally I'd like to use something similar just in case I do have to rework it again, rather than something more permanent.
Does anyone have any suggestions?
