I need help with this fog machine, heres a quick run down. 400 watt, pump works, heating coil heats up, BUT, it shuts off and doesn't go on, when you would think it does, not sure if there is a wiring problem, anyone know how these things are suppose to be wired, or if my temperature controller thing is shot. this thread has been some help, but maybe specifics,wiring diagram etc, would be even better.
cheers
side note , i think the switch has been altered, so lets see if i can figure out how to add some photos.....
