I have an LG 31MU97-B monitor that has gone dead for the second time. The mainboard was replaced at the beginning of 2018 which, of course, solved the problem, but I don't really want to go on buying mainboards for it every 2 to 3 years.
The problem is most probably an EEPROM, an MX25L8006EM2I-12G.
I took the monitor to the company that replaced the mainboard before, and they said they hadn't a SOC8 adaptor for their universal programmer – acquisition, labour, and it might not being the problem would make repair an uneconomic proposition.
Reading into it, I found I could buy a CH341A USB programmer quite cheaply. However, further reading disclosed that although the programmer could power the chip at 3.3V, it sends programming signals at 5V. Furthermore, no CH341A lists an MX25L8006EM2I-12G as a chip it is suitable for. There is a hack of rewiring the CH341A to use the 3.3V line as its own power supply – it looks a bit messy to do on a new piece of equipment, I've an eyesight problem, my only soldering iron may be too big for the job, all-in-all it's not really something I'd really like to attempt.
Is there a programmer I might economically buy to do this job once every 2 to 3 years? Is it likely I'll find a repair man with the right equipment to do the job economically? What should I ask one to make sure he has the equipment for the job?
