I've had a 3456A for a while that I love, but it's lonely. So I got a good deal on a second one on ebay that I was hoping to repair. I've spent some quality time with the A10 Inguard Power Supply board over the last few days but I've come up against a wall. I'm betting that several of you guys know the insides of this thing pretty well and I'm hoping that someone might take pity on me and help me (a relative beginner) out.
I took the seller at their word ("burning smell," etc.) so when it arrived I didn't bother plugging in or turning on. Upon disassembly, the obvious problems were on board A10, Inguard Power Supply:
- C19 was 100% dead short and bulging. But not leaking (yay!).
- Scorching on PCB around diodes CR9 and CR10.
I swapped out C19 (as well as all other electrolytics). As for the (possibly) burned diodes, other than the darkness on the PCB, they both actually looked OK. I tested both out of circuit with diode test function of a handheld as well as my 34401A and both showed a forward drop of .5 to .6V and open circuit when reversed. I still wanted to replace them, but based on their size, they look to be fairly beefy components and none of the rectifier diodes I had sitting around look like they have enough capacity. So I put them both back in, then checked continuity to make sure that both CR9 and CR10 were connected properly to other components on the board - they were, so the PCB wasn't burned as badly as I originally feared and the traces were OK. In addition, there was NO continuity where there shouldn't have been from, for ex., the burning causing carbonization.
I then plugged A10 back into the transformer, disconnected from everything else, and powered up. No smoke, magic or otherwise. I tested A10 output voltages: +15, -15 and -18V rails were all perfectly fine. But the +33V rail, shown as "+33V to +46V" on the schematic, *started* at about 47V and steadily climbed to at least 49V. The 5V rail was similar - it started at about 5.4V, but climbed to at least 6. It was about this time that I "smelled heat" and noticed that CR5 (1N5366B, 5W/39V Zener) was incredibly hot, so I shut it down.
I then did a bunch of A/B testing with the A10 board from my good meter - so far, the only difference I've seen is that the good board has a stable max of 47V on the +33V rail (say at JMPR2 relative to the TP1 ground test point). But the broken board starts at 47 and just goes up from there.
Because the +5 and +33 rails are the only problems, I've generally ignored the VRegs on the +15, -15 and -18V rails - in particular, VRegs U2, U3 and U4. But since that 5V output was high, and since the +33V rail is (apparently) partially derived from it, I thought I'd take a shot and put in a new 7805 in a TO-220 pkg since I happened to have one. This made no difference at all.
I've really tried testing for shorted components everywhere. I've also tested all diodes in-circuit (fwd and rvs), including the bridge rectifiers. So I believe I've eliminated all the REALLY stupid stuff. The problem Zener CR5 has also been tested out of circuit and normal fwd/reverse tests are normal, although I did not try testing the 39V breakdown voltage. Is that the place to start? Should I perhaps just obtain an exact replacement for that item and go from there?
Is there someone that might be kind enough to give me a bit of guidance on where to go next?
