Novice here. I'm trying to repair a Suzuki Omnichord OM-27 that has a buzz. I'm operating it with a new replacement 12V 1A center-negative AC/DC power supply. It wants 600mA, I believe.
The only schematics available for the OM-27 are here, and they are handwritten and pretty hard to understand:
https://drive.google.com/file/d/0B8-MOD-DNXkHNzY0ZWE4YjAtMDNlZi00YTY0LWI5YzYtNzNjMDhiYTI4MzJm/view?sort=name&layout=list&num=50&resourcekey=0-EqLlWTBcP2OV2e0ZDq-aXgThe buzz is present in both the audio out and the onboard speaker. It gets much worse when I put my hand near a specific 1uF 50V electrolytic capacitor near the volume pot, and it becomes deafening if I touch the top of it. (I know about the dangers of capacitors. This was a calculated move) Tapping it with a chopstick didn't do anything special. It seems to be acting as an antenna.
- I've replaced that capacitor, but that wasn't it. The new one behaves just like the old one. I also replaced a couple capacitors around this one: a 0.01uF and another 100uF electrolytic cap.
- I've tried a second, identical, brand new 12V 1A center-negative power supply, same noise.
- When I tried probing around with an audio probe plugged into a guitar amp, I noticed that the buzz disappears completely when I connect the ground trace to the amp cord's TS sleeve (ground). The antenna effect disappears, I can touch the cap and it doesn't make a noise. The amp and the unit are connected to the same power outlet. The same is not true if I ground the trace from the same point, or any other point, right to the unit's power connector's ground. So, I'm assuming it's not a broken ground trace in the unit.
I don't understand what's happening. I have theories and questions:
- Why would me touching or even just hovering above a known good cap (the first one I replaced) emphasize the buzz? What's happening here? I'm I acting like an antenna? Induction from my static?
- Why would connecting the ground trace to the amp's input ground remove the buzz? The current wants to go back to the power adapter, so it's not like it's draining out through the amp's ground into the wall.
- Should I concentrate my search near that antenna cap, or could it come from anywhere?
My current theory is that a component has failed and is shorting to ground, which causes a potential on some part of the ground trace, and/or a lack of potential on the circuit, giving a ground loop type problem. Does that reasoning make sense? It doesn't explain the whole antenna cap effect.
- What should be my next trouble shooting step?
Thanks! I learn every time I post here.
