I bought an inexpensive resistor kit on eBay from a good Chinese supplier and all the resistors I've checked, and I've used many, check out within the stated tolerance. One problem I have with all of them is the painted bands aren't strong primary colors so it is easy to run into the same problem you are having, guessing what the color is actually meant to be.
