Indeed.
In the same patent, they detailed the tests used to qualify formulations -- some MIL and ASTM standards I think they were, where a copper sheet is thoroughly cleaned and buffed (with steel wool), floated on a lead bath (not tinned, at least not thoroughly!) and left to oxidize in air for an hour at 400C, or a minute at 500. They say the coating is fractional microns of cuprous oxide, giving it a delightful flat brown appearance. Seemingly even more impressive is using the solder on it, getting significant wetting (measured by how far a blob of solder and rosin, I seem to have missed how much of each -- spreads out). I know the fluxes I have here, and my patience level, well enough to get out the sandpaper or steel wool if I saw a surface like that.
They also describe a corrosion test, which is vacuum deposited copper on glass: very thin, so when the rosin is cooked on it (how hot and for how long, was garbled, I was just reading the OCR..), if the copper oxidizes much due to air or rosin, it will disappear pretty much instantly; and the affected area is measured optically.
Hmm, hydrogenation should make the "resin" more lipophilic than alcohol-philic (heh, I don't think there's really such a thing as that, it would just be plain hydrophilicity, wouldn't it), that may be why it doesn't mix with petroleum jelly.
Citrates would be like partial esters, I suppose? Alkylated to get them in solution, but not fully so there's free acids to be active (and the oxygen-studded citrate will be more active than the chunky abietic acid is); and pyrophosphates would be the same idea? And imides like the uh, whatever the OSP stuff is, probably? Yeah, I can see that. Some of those might be pretty easily accessible to the home chemist; hydrogenation a bit less so. (I imagine Pd:C or such should do the job, and H2 gas is easy enough to generate on demand -- it's one of the easier organic reactions to perform -- but it's a reaction (and subsequent workup, augh, filtering catalyst from sticky sticky resin solution?
) nonetheless, not just mixing raw materials together.)
