Author Topic: Restoring photos from broken Nokia Asha 300  (Read 585 times)
Offline dtm_Topic starter
« on: August 18, 2024, 05:46:11 pm »
Hi.
I have old broken phone Nokia Asha 300: https://www.gsmarena.com/nokia_asha_300-4279.php
It does not start - when I press the power button (the red one) nothing happens. Charging it using an USB cable plugged into a laptop also does not work. However, my goal is not to turn on this phone, but to somehow restore photos written on its hard drive. I disassembled it to get access to the motherboard, but I cannot figure out where the internal memory is located and how to get access to it. I send pictures of the motherboard as attachments:
1) my original photo
2) the photo with names of the elements I was able to recognize
My questions are:
1. Where can I find the internal memory on that motherboard?
2. Is there any way to get access to data stored on it externally, without starting the phone?
I am a kind of noob in this topics, so any help will be appreciated.
Offline fzabkar
Re: Restoring photos from broken Nokia Asha 300
« Reply #1 on: August 19, 2024, 10:59:57 pm »
Service manual:
https://elektrotanya.com/nokia_asha_300_service_manual_l1_l2_v1.0.pdf/download.html
The memory appears to be the K5 IC on page 20.
« Last Edit: August 19, 2024, 11:08:48 pm by fzabkar »
The following users thanked this post: dtm_
Offline wraper
  • Country: lv
« Reply #2 on: August 19, 2024, 11:07:09 pm »
Note this phone won't turn on without working and at least a little bit charged battery even with charger attached. So first thing you should do is to check if there is actually voltage on its terminals. As of reading the data without making the phone to turn on, forget about it.
« Last Edit: August 20, 2024, 01:28:21 am by wraper »
Offline wraper
  • Country: lv
« Reply #3 on: August 19, 2024, 11:20:10 pm »
Also I'm not 100% sure but its micro USB port is likely for data only and cannot be used for charging similar to other Nokia phones from that time.
Offline Postal2
  • Country: ru
« Reply #4 on: August 20, 2024, 03:36:27 am »
Connect the battery and charge it by connecting the adapter according to the picture (the minus is connected to the ground, check it).
« Reply #5 on: August 21, 2024, 06:48:04 pm »
According to this manual: https://files.customersaas.com/files/Manual/Nokia_Asha_300_User_manual.pdf it should be possible, I don't have any other information.
Anyway thanks to you guys for your insights. It will be tricky thing, but I will try.
Offline fzabkar
« Reply #6 on: August 21, 2024, 07:02:56 pm »
I found the same thing.
Specs:
https://www.phonearena.com/phones/Nokia-Asha-300_id6511
FCC filings for FCC ID PPIRM-781:
https://fccid.io/PPIRM-781
User manual:
https://fccid.io/PPIRM-781/User-Manual/Manual-1558595.pdf
The manual also states that the Nokia 300 (is it the same phone?) can transfer data over USB and Bluetooth.
« Last Edit: August 21, 2024, 07:06:40 pm by fzabkar »
