Hi all,
Fist forgive me if I am in the wrong part of the forum, I just need expert advice on vintage electric motors, so feel free to move this thread.
We are trying to bring up safely an old vintage 3N industrial induction asynchronous motor, squirrel cage - is quite heavy, has a few HP, sadly I don't have the label right now. I have an idea on the steps, but I'd like to get an opinion. The motor mechanically seems perfect and spins with no friction. It seems to have coils connected in star configuration.
My idea:
1. cleaning the old dirt. open if necessary
2. measure insulation, coil-to-coil, and chassis (with multimeter or even high voltage tester if I can)- If needed open the star connection to measure all individually.
3. replace bad wiring, check the internal wirings that are going to the motor, including PE and chassis
4. get a variable frequency controller (rated for such motor), we have 1N and 3N with differntial protection available to the controller
5. playing around, starting slowly? <- this is the part I am not sure about, on top of wanting to double check the previous steps.
Thanks for any 2 cents given! Let me know if you want to know something more in details, I'll provide the info.
