Hi!
I'm not sure what HiFi Engine's manual is like as they blocked my account after downloading one small manual from them, but I can recommend you download the s.m. in two parts from Elektrotanya – it's a beautifully done high quality colour scan with the original top layer pink track tints on the layout drawings and all the data is beautifully clear & readable!
For the F.M synthesizer to lock it needs a local oscillator sample and the i.f. which is sampled to determine the frequency by which the local oscillator is out, usually by internal count–down methods in the PLL chip!
You'll need to pay particular attention to the +32V LT supply feeding the FM synthesizer PCB first, so turn to pages 46 and 47 of the service manual and check the following components on power supply 1.780.110:–
A) C4 for low capacitance;
B) Q4, Q7 and Q8 for defects or leakage;
C) +32V adjustment preset R21 for dud–spots – bin it and fit a new one if you're doubtful about it;
D) –15V from 7915 stabilizer I.C., the error amplifier Q4's emitter is controlled from this line!
The +32V doesn't supply a large current so if you have a bench power supply available, it might be worth your while feeding +32V from this via a 1N4148 diode to J1/26 (violet/purple leads) and chassis (+ lead to J1/26) and then switching the tuner on from cold to see if you can tune in an FM signal straightaway!
I would certainly try this simple test first – if you've not got a bench power supply unit, four PP3/1604 type batteries wired in series with a 1K resistor to give 36V will do – the opamp is rated +44V max. and a few minutes @ 36V while you prove the fault won't do it any harm!
If your +32V supply is correct or repaired as the case may be, next step is to turn your attention to page 54 of the s.m., and check what's happening with integration stage IC4 (LF356) on the synthesizer panel 1.780.151.81 – the inverting i/p pin 2 is connected to the pulse trains from the "FUP" and "FDN" outputs from the PLL i.c., (Q3 and Q4 are inverting transistors for the pulse–trains from the i.c.), and the non·inverting input pin 3 is biassed to half–supply voltage by R36 and R45 – the output pin of IC4 is a d.c. voltage that should change in response to the tuning controls!
If the supplies and the +2.5V at pin 3 of IC4 are correct but it's output is not responding to the tuning controls correctly, we need to know if you've got an oscilloscope and a counter (or a modern digital 'scope with readouts built in!) as fault–finding the unit after this point really needs one to follow thro' the oscillator and prescaler divider outputs!
Chris Williams
