Greetings EEVBees:
--I just came across this fellow "feedbackloop". In the attached video he unwinds, repairs, and then rewinds the main toroidal transformer, and fixes an Array 3664A bench power supply. Now it did take a bit of work, but nothing difficult. If you happen to have a similar power supply, or even an expensive audio amplifier, with a toroidal main transformer, this technique could save you a ton of money, an allow you to keep a valuable piece of equipment rather than trashing it. I hope this will be of help to someone.
"I believe that at the end of the century the use of words and general educated opinion will have altered so much that one will be able to speak of machines thinking without expecting to be contradicted."
Alan Turing 1912 - 1954
Best Regards
Clear Ether
