Thank you for the replies,
So as far as parameters go, there are 40 turns per coil, with 0.2mm wire, that much I kept track of. I have some slightly larger wire (0.25mm) but the windings weren't super tightly packed into the slots so I think there will be room, if not i'll get some 0.2. I have fish paper, although the old stuff stayed in and I doubt I could get it out anyways. Getting the old windings off was hard due to all the shellac, so it was really impossible to see which commutator bars were connected to which coils. The pitch in mine is either 3 or 4, and I would have though it needed to be a multiple of 8, but perhaps not (see below). The main thing I can't tell is the commutator pitch I guess, and I'm trying to make an educated guess.
My understanding of the wave winding is that the commutator pitch is greater than the coil pitch, here for example it would be a coil pitch of 5 and commutator pitch of 9
if I watch this guy for example
he seems to mark a commutator bar, and then moves 3 slots (inclusive). It is (as best I can tell) a 12 slot armature, and if the commutator is lets say 11, then he winds 1 and 6 so a coil pitch of 6 and commutator pitch of 10, assuming he then goes to 8, but I can't see which he goes to, there is a cut in the video, he goes on to wind 7 and 12, I am assuming because this is the parallel path but now there is another commutator bar connected.
anyways, based on the fact that I have an 8 slot, and the pitch appears to be 3 or 4, is there a way to deduce what the commutator pitch would be? I will be hitting the books (thank you amyk) to try and answer this question but if you know, by all means jump in.
also, to point 6, I have check that the bars are not shorted.
