Hey guys,
I need some help and advise please.
I am wanting to rework a MC68000 CPU onto an Amiga 600 motherboard. I have a hot air station but I mainly use this for removing small surface mount parts and have not tackled anything like this.
I suspect a problem with the CPU connections as I purchased a ram expansion module that clips over the CPU. I started getting some error codes and the computer not starting so started to investigate.
I found that the HALT pin on the CPU was not connecting to the pad. I did manage to fit this just using some flux and got the system running again but as soon as I try to do anything once on the OS the PC freezes.
I do not know where the other connections go so cannot follow traces to determine if other points are not contacting correctly.
The CPU looks like the attachment I have below.
.png)
Any tutorials on doing something like this? Any assistance would be much appreciated as I don't want to let this one go to motherboard heaven.
