Hello,
I would like to re post old thread, now amp is build as it should,
Issue is that signal don't boost at all, I have one power supply, for drain and gate. On gate side I have voltage down converter, and can confirm that voltage converter can supply actually around 12-14V 1.5A under working condition, because I try with some cheap amp operating around12-14V, and voltage converter starts acting funny around 1.5-1-6A. From manual gate side needs around 1A and 12V.
I actually don't have proper power supply on drain side, it's some cheap Chinese Voltage/current adjustable power supply, but can provide only 4A at 53V, and manual says 15A and 53V, don't know if fet needs that much current when actually starts, although MRF300AN and MRF300BN are not toy gadgets.
Manufacturer didn't provide any manual/debug manual, I don't know how to connect output coaxial cable, now is only central wire connected, usually ground and plus are connected on second magnetic coil (before output SMA, like on picture).
