I remember the 50W Maplin amp very well, it was a pretty nice sounding amp but a flaw in the original design was the use of nylon nuts and bolts to mount the output transistors rather than using top hat insulators with steel fasteners. The nylon fasteners would fail, shortly followed by the output devices so if yours is still using the plastic parts get them changed out ASAP.
