Author Topic: RIFA capacitor replacement  (Read 833 times)
Offline maeshlmaentTopic starter
  • Country: tr
« on: September 12, 2024, 11:34:26 am »
Hello everyone,
I have two old rifa caps in a snubber circuit(I guess). I couldnt find any document about them, please can you advise me modern caps instead of these rifas.
Offline Ice-Tea
    • Freelance Hardware Engineer
Re: RIFA capacitor replacement
« Reply #1 on: September 12, 2024, 11:57:39 am »
Safety film capacitors. Rated X2 or Y2 depending on whether they are L - N or L/N - EARTH/CHASSIS.
Offline madires
  • A qualified hobbyist ;)
« Reply #2 on: September 12, 2024, 12:06:54 pm »
If no safety caps are required you could use Wima MKP series.
Online wraper
  • Country: lv
« Reply #3 on: September 12, 2024, 12:08:29 pm »
These are not safety caps. Rifa made multiple series of that garbage. They can be replaced with regular polypropylene capacitors. Polyester should be fine too in most cases.
Offline Ice-Tea
« Reply #4 on: September 12, 2024, 12:15:36 pm »
They are most often found on primary side, including filters etc. I stand by my recommendation.
Online wraper
  • Country: lv
« Reply #5 on: September 12, 2024, 12:20:42 pm »
Safety versions are marked as such. You don't need safety capacitor for snubber.
https://file.elecfans.com/web1/M00/20/FE/ooYBAFmk4f2AOsh6AFozsxcyW-I075.pdf
PME2616 General Purpose
Offline Ice-Tea
« Reply #6 on: September 12, 2024, 12:40:06 pm »
I stand corrected. I'll rephrase to "Safety film capacitors. Rated X2 or Y2 depending on whether they are L - N or L/N - EARTH/CHASSIS. Unless you're 100% sure a safety rating was not part of the original part or should have been given the application" ;-)
Online factory
« Reply #7 on: September 12, 2024, 12:54:06 pm »
The pictured parts are DC rated interference suppression capacitors, i.e. PME261 from this pdf.
Offline Ice-Tea
« Reply #8 on: September 12, 2024, 12:58:42 pm »
Yeah, wrapper provided a pdf as well. Hence me grudginly admitting I may have been not 100% correct and modifying my original statement in the most minimalistic way possible ;)
Offline Gyro
« Reply #9 on: September 12, 2024, 07:21:50 pm »
The USP of metalized paper capacitors like the Rifas is high dV/dt capability. Polypropylene would be the safer (in terms of longevity) replacement choice of the two.
Best Regards, Chris
