I wont argue with PKTKS, but our open frames and closed frame psu(s) like the OP have somekind of load or an bleeder resistor to empty the output capacitors on the board itself, you can power them and test them without any load on the output, ad they are stable and rock steady.
We have many of them, Condor and Meanwell mostly, from 5vdc up to 54 volts, none of them needs a load to start, only one of them have a remote power on, if we enable it with an jumper. ?
I ve seen tons of smps, they dont always need a load to sart and run ... the only ones i know know to do that are the computers and servers power supply (ies)
You have many topologies to implement an smps, buck boost, fixed or variable frequency (ies) etc .... it depend on the design you need or use i may say.
Edit : i have at home, Corsair and Thermaltake psu, they start without the mobo or any hard drive on them, just need to short the power signal on the 24 pins plug.
