Author Topic: Rigol DP712 "Fan abnormality" message - How to clear it?  (Read 716 times)
Offline AndersJ
« on: July 20, 2018, 11:30:01 am »
The message "Fan abnormality, output disabled" is shown on the display.
The message appeared when I disconnected the fan to measure the current,
hoping to replace it with a lower noise fan.
The message persists, and the output is disabled, with the (original) fan connected and running.
How do I clear the message, and restore normal operation?
/Anders J
"It should work"
R.N.Naidoo
Online _Wim_
Re: Rigol DP712 "Fan abnormality" message - How to clear it?
« Reply #1 on: July 20, 2018, 02:59:36 pm »
Is it a three wire fan with speed feedback? If yes, could it be that the fan connector was connected incorrectly (only 2 pins connected) Did you connect the connector reversed (+ and - the other way around)?
Did you turn power completely off (iow removing the power cable)?
Offline AndersJ
« Reply #2 on: July 20, 2018, 05:44:30 pm »
Two wire cable, correctly connected.
Complete turn off.
Only visible anomaly is that the fan is not physically mounted on the chassis.
I doubt that the controller can detect that.
"It should work"
R.N.Naidoo
Online _Wim_
« Reply #3 on: July 20, 2018, 06:22:04 pm »
Could be the reason. The controller probably monitors the power consumption. This is the reason why sometimes an additional resistor is added to dissipate some additional power when a "silent" fan is installed..
When air flow is retricted, power consumption is higher... Try to restrict air flow with your hand and check if the problem goes away or reinstall the fan in its normal position...
Offline AndersJ
« Reply #4 on: July 20, 2018, 07:24:48 pm »
Just to clarify, I’m still using the original fan.
Haven’t found a silent 70 mm fan yet.
Hand restriction did not work, or I did it incorrectly.
But,
when I put it back properly, the error message disappeared.
The speed is high for a few seconds right after turn on.
Maybe it does some form of diagnostics.
I remember thinking it took longer to rev down when the fan was out of the case.
Perhaps that was the timeout, when it gave upp looking for a proper fan?
I didn’t realize a simple chassis fan could be so sophisticated.
I need to analyze this better.
Thanks for broadening my thinking.
"It should work"
R.N.Naidoo
Offline jmelson
« Reply #5 on: July 20, 2018, 08:09:52 pm »
There may be a self-heating thermistor on the main board that senses that the fan is cooling it.
Jon
