I'm grappling with the challenge of restoring this ancient treasure that I stumbled upon.
Green boxed components have been replaced due to damage.
The main issue at the moment is the power draw:
Around 9 mA when turned on,
About 11 mA when turned off. No logging is active.
When I touch G4 with a probe or a resistor connected to ground, I observe 0.15 mA in the OFF state. I believe this is a good value, considering that a part of the circuit is always on.
Everything is functioning well except for the function generator. While I am receiving pulses on the gate (G4), both the drain and source remain at 0. It's possible that certain components or vias are missing (yellow box?) or damaged on the drain/source side.
Would anyone have advice or a schematic diagram pertaining to this meter? It would bring me great joy to fully restore it and acquire new knowledge. Thank you!
