From the photos I have seen it looks like an LCD. As you will know if you have any device with an LCD display and a contrast pot, the wrong setting can give a very low contrast display irrespective of backlight illumination. My experience is that LCDs themselves in general do not fade, at least not significantly, so if the backlight is as bright as ever I would investigate the LCD driving circuitry before assuming you need to change the LCD.
